The weak link in the Oasis is the domestic water heat exchanger. The usual failure is due to freezing. Freezing it will not even try to put up a fight. The ease of this failure is the main reason the units call for non-poisonous boiler fluid. The failure will usually only be internal, you will not see external leakage unless you really swelled it up. To test, you can use a cooling system pressure tester on the boiler cap. If turning on the domestic water raises pressure in the boiler you confirmed the failure. The heat exchanger is a some what off the shelf item. You can source elsewhere and if you want to be creative you can also use a larger one.
