How To Power Starlink Standard (Gen3) using PoE?
I'll give T-Mobile another try. Was very easy ordering online, now to see how long it takes to get it. The cellular's all add up but they seem to be outperforming still here in 2026.
This is the first time I'm breaking out the Starlink Gen3 to give it a try. Really don't need it here but glad I tested it before I needed it. First thing of note, the Starlink app calls it "Standard 4" and after some research it's the same dish as Gen3 apparently with a newer Wi-Fi setup.
The PoE product recommended in this thread for Gen3 doesn't work, sadly! It's also no longer on Amazon, probably a reason for that! So the newer option on Amazon here is a 200W version where the old one was 150W and obviously insufficient to power the dish Gen3/Standard4 via PoE.
I got the new one today, wired up, backed it with a 20A fuse, and it works great. Chat GPT recommended a different one though, so I did order that one which is 350W and seems to be a more professional model to use.
I also found my Flagpolebuddy Gen3 dish pole mount which I know they 3D print was poorly printed and the locking bar was broken off. Amazon sells this one which is aluminum and is working great. I'd much rather have a metal adapter than 3D printed.
Sadly Elon is not competing with my Pepwave BR1 Pro 5G (TK - x62's) which is pulling 350 down on Verizon 5G where Elon is only doing around 50'ish on average.
All your links are for the pole mount
Sorry. Will fix in the morning.
