OTR Mobile - Unlimited AT&T Hotspot or BYOD
MapNerd
RVF 1K Club
Prince William, VA
Ventana 4326
2020 Ford F-150
Was searching for over a month for a plan I could use for my WiFi Ranger SkyPro LTE that came with the RV. I originally planned to replace this with a different setup but wanted to give it the benefit of the doubt before proceeding to drop that cash and swap out the equipment. Additionally, I also needed to find a plan that wasn't priced ridiculously.
The WiFi Ranger comes with an unactivated AT&T Nano SIM card and which they expect you to activate with one their Connected RV Plans. Well, those plans are less than adequate, considering they are $90/month for 22GB at most. That might work for some, but for a full timer it's a nonstarter. So I've been scouring for an unlimited AT&T plan.
Tried going the Harman Spark route - no dice because AT&T shuts you down once you transfer the service to a new SIM card outside of the Spark.
Tried going with Visible, but they only support certain devices and the service does not work on other devices. I tried taking my wife's visible SIM from her iPhone and putting it in my iPad - no dice. Service didn't work.
Finally, I came across OTR Mobile. Unlimited AT&T Data for $60/month. You can activate new SIM with them if you already have one, you can order a SIM directly from them, you can order an activated hotspot directly from them. I took the unactivated SIM that came with my WiFi Ranger, gave them the SIM number, waited an hour and popped it in. Voila. It's worked great for the last few days.
They make no reference as to data caps at all, just speed. I wonder if they are trying to fly below the radar for some reason?
-edit-
I found this on the front page:
$60/mo Unlimited Internet on Mobile Hotspots. No Data Caps. No Throttling. No Contracts. Get The Package That Works Best For You.
so I guess that is pretty plain speak.
can't say but this week, we'll putting it through its paces with Netflix, Amazon Video, Skype for Business Video Conferences, Slack, Email, School and everything else. I'll report if anything goes sideways but let no news be good news.
I agree - this is a good option for those that don't want to go the Mobley route.
Don't want to? I've haven't seen a way to. Thought it was too late. Isn't the mobley like $20/month unlimited, no caps, no throttles?
Does anyone know if AT&T is still offering the Moble plan for $20 / mo?
@redbaron , does the physical Mobley device get used for anything other than providing the IMEI number For activatio?
No, the mobley is not used once the IMEI has been given to att to get the plan. You could just sell it again possibly. I kept mine just in case.
@redbaron ,Ronnie...
Have you successfully activated a Mobley purchased on eBay? How recently?
I'm concerned about spending $100+ for the device and not being able to transfer to me. Everything I've read suggests the service is grandfathered to the original purchaser only.
Thanks.
@BuckyII , I have registered 2 from ebay, but last one was 6 months ago.
I would call the att phone number for the mobley discount and see if the offer is still available if you provide the imei.
Its been long enough that I understand your concern. Its a useless device otherwise.
Well, I bit the bullet and purchased the Pepwave Max BR1 Mini with the Wan License. The Wan license enables a hardwire connection from my current WiFi ranger. (Not sure if I really needed this, but it's done). My main objective was better access to the internet...I did not want to pay Winegard for their data plan.
So far:
  • Moved the MyRozie Cat5 from the WiFi Ranger to the Pepwave
  • Connected the WiFi Ranger to the Pepwave
  • Did initial setup of Pepwave
So far, so good:
  • From the Pepwave control panel, I have access to the WiFi ranger signal.
    • Can also see most of the same Wifi signals on the Pepwave...not sure if I'm gaining or losing speed by going thru the WiFI ranger...will test that later.
  • MyRozie seems to be working properly
Now I need to figure out how to get 1 or 2 sim cards into the Pepwave so I have direct access to the internet without depending on local WiFi
Questions:
  • My phone plan is with Xfinity Mobile - I will try to "add a phone" and put the sim card in the Pepwave - has anyone attempted this?
  • Still struggling with buying a Mobley device on eBay (cost is $125 - $150) and hope I can get it activated. Has anyone done this recently?
  • There are lots of expensive plans with 1 or 2 year contracts that will provide the sim card I need. However, we are only on the road 3 - 4 mos / year.
    • Can someone point me in the direction of a decent plan with a short term contract?
Thanks...
Nice progress so far. Make sure you update the firmware on the pepwave to ensure the latest is installed. System toolbar area, firmware on left. You may also want/need to update the cellular modem firmware which is done in the private support area by changing the end of the URL to /support.cgi
Thanks @Neal ...I updated the firmware.
Also signed up with T-Mobile for their Mobile Internet plan. No contract, month-to-month, $10/mo for 2 GB of data usage. Although I have internet at my RV condo, this is cheap enough for good backup year around. Put the sim card in the Pepwave and was able to receive adequate signal inside the RV while inside the condo. Success!
T-Mobile has other plans with more $ and data per month...may upgrade while travelling.
Will now shop for another service for the other Sim card slot and compare with T-Mobile.
I did a Sprint plan that was 120GB when I signed up, somehow it showed 200 GB so I must have gotten upgraded. It was around $60/mo I think. I cancelled it when the pandemic started in my efforts to shed non essential bills. In some places it was good but Sprint coverage is spotty. The merger with T-Mobile will be interesting and may be a viable option. My $.02 - you'll burn through that 2 GB in an instant so be cognizant of what you're doing when on it. Preaching to the choir....
I agree...however, the 2GB should work for when not travelling as a standby for MyRozie communications. When travelling, will need to upgrade and/or have other plan.
