- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Boy, dem' diesels must give some kind of smooth ride.I've had these on for over a year and no issues with anything broken or marked.
I actually 3D printed these hooks but any hook you want to use will work.Are this just coat hooks for above the sink coffee cups>?
Of course you did. Why would we think anything else?I actually 3D printed these hooks but any hook you want to use will work.
The holes in the frame to move the rails over are actually already predrilled and the rails that hold the glides are clearly designed to go against the frame so the drawers can be wider as the rails have cutouts to avoid frame bolts in exactly the right place. Just Flexsteel squeezing every last penny they could out of it, I guess. Probably saved them 100 sheets of plywood over the course of 5 years.Well done @MapNerd. I never understood why those drawers are as small as they are.
I wish our doors were reversible. They open the same direction as yours and it’s annoying. Would be much better and give more space if they opened towards the escape door.The problem: The dryer door does not stay in position while transferring from washer to dryer.
My solution was to glue a 5/16" diameter neodymium magnet to the hinge of the cabinet door. It can also be seen in the photo above.
Happy now to not clunk my head or fight with that door any more.
Maybe if you turn the washer & dryer upside down........I wish our doors were reversible. They open the same direction as yours and it’s annoying. Would be much better and give more space if they opened towards the escape door.
Just keep following my advice @MapNerd I will never steer you wrong?
