GPS using an I PAD
ericbev
Hello - I am looking for a large screen (maybe a tablet) to use strictly as a GPS in my new RV - I prefer Google Maps to navigate. I have a Verizon account so I can get a signal at all times (hopefully). The Jayco comes with a terrible system and I really would find it difficult to replace all the functions it has - GPS, Bluetooth, Radio, CD, Back up camera, etc. Does anyone have a recommendation for a system(I pad or something similar) that I can mount on my dashboard (need recommendation for mount as well)?
I can’t advise on a tablet, but when it comes to mounts, this is the place:
My configuration consists of a small iPad Mini 9” which is RAM suction mounted to the passenger side window. This is for my wife to use with one of several navigation apps; whether it’s WAZE, GoogleMaps, or Apple Maps.
Remember that there ARE apps that allow you to download maps to be used offline, for when cellular data is unavailable.
RAM mounts are fine. I’ve found using the short arm the best. Since the iPad is heavy, using a long arm will slip on the rubber ball, no matter how hard you tighten it. But, they are about a third of the cost of the aviation solutions.
One of the failings of Google Maps is that it routing is for a passenger car and not a RV. Don't get me wrong we love Google Maps and use it on a tablet every time we travel but we have a Garmin RV GPS as our primary source. It does a very good job of keeping us off roads a RV shouldn't be on in the first place.
I ended up buying a Sony XAV-AX7000 - I hope it will work well - just hated the SOUNDSTREAM system that came with my Jayco Alante
If you use an iPad for navigation, make sure it has GPS capability! Generally, only the iPads with cellular data capability have GPS built-in. The WiFi only iPad does not have GPS installed and must use a Wifi connection to operate Google Maps. Just saying from personal experience.....
Sorry to resurrect an old thread, but if you have a WiFi only model iPad you can buy a garmin glo to have gps capability. my new iPad is gps enabled but I used the garmin glo on my old iPad as a chartplotter for the boat. garmin glo is around $100. I now upgraded to the 2020 iPad Air with the gps function So it’s no longer really needed For me. Lots of people that transit the great loop have told me that’s all they use for navigation.
With any “mobile” device like an iPad, in order to have GPS mapping, it must be able to obtain those maps somehow; aka, the internet. With maps such as Apple and Google, those maps CANNOT be entirely downloaded for “offline” use.
So, not knowing WHAT mapping software you intend to use, I can tell you that you’ll most likely need to have a constant internet connection. Therefore, a WIFI ONLY iPad must be connected via some type of source such as a mobile router (PepWave) or hotspot.
HTH
HTH
And, you will NOT always have an internet connection while driving; there are always dead spots!
The best solution,,,and, the cheapest in the long run...IMHO is to buy a dedicated, RV-specific GPS like the Garmin RV 890 or the new Garmin 1090 if you need a bigger 10“ screen. And, even they will hit a satellite dead spot once-in-a-while. Passenger-car maps and tracking just don’t get it with larger vehicles like motorhomes, 5th wheel trailers, large travel trailers, etc. unless you enjoy turning around a lot, and on very narrow roads. :rolleyes:
Good truck apps to keep you on safe routes usually require an annual subscription. I do not subscribe to software, so I ended up with a Garmin760 truck GPS. Car gps's and apps have gotten me in trouble- taking me places where an RV cannot go.
I use my IPAD at times. It does have Cell service and WIFI. Like the IPhone it will download the maps after you activate you direction, then update via Cell or Wifi every once in a while.
Hate to be different but...OK maybe I do!!!
I use Google maps. I travel many places where service is really questionable. Listen folks, unless I reroute when I have no service I can complete the route without any problem. This has to mean the route map is stored on the phone.
Note that I loose everything if I reroute.
Co pilot GPS has offline maps and allows you to select your vehicle size to avoid those nasty low bridges etc. I only use google maps, Apple Maps, etc.. for reference, never for core navigation. CoPilot looks great on my iPad Pro and tho not perfect, it has worked pretty well for me for several years. I do suggest that any travel to remote/ unknown areas be reviewed on Google Maps satellite view for problems, as Co Pilot has provided some suboptimal routing a couple times.
Kevin,
Hmmm, not gonna argue with you on “if” your’s works for you or not. But, I can argue that OFFLINE mapping for Google is NOT automatic, according to experience and their documentation.
In order to have OFFLINE use on a Google Maps, you must DOWNLOAD sections of maps while you have an internet connection. THIS IS NOT AUTOMATIC, and not based upon your routing; you have to select areas you “intend” to travel, then Download that section. This can be clunky, as well as Google up time and space.
Most people I know, haven’t a clue that this feature exists; it’s quietly tucked into your profile icon in the upper right of the iOS screen.
Here’s a screen shot to show you.
Now, all this said...there IS a possibility that YOU have already pre-downloaded sections of your travel and may not know, or have forgotten. Google Maps will keep those offline maps stored until you delete them; and even make periodic updates to them...but usually with a prompt to ask you.
Hope this helps.
