- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Do you remember the first time you went to a truck stop to pump diesel? I do and I had to ask the nice trucker next to me how to use the pump. I figured posting this may help a new RVer that may have the same questions and can be better prepared for that first fill up. Mine was late at night, struggling to find a gas station, wondering how far I could go, where I could go, etc. I came up on a TA Petro station and the learning began. Let me add that the hustle and bustle of the loud trucks, the pace of the truck stop, all were daunting.
So you're at the truck stop pump and hopefully you have a TSD Fuel Savings card but maybe not. Swipe your card whether TSD or Credit Card and start the process. Various truck stops have varying workflows at the pump from Loves, Pilot/Flying J, TA Petro, etc.
If you need DEF and have to pull forward, do so promptly but carefully. I'm not sure how long the DEF pump will wait, lately I have not had an issue, initially I couldn't figure it out.
Congrats, you did it! Now pull forward to the yellow line if you plan to go inside the store so the truck or RV behind you can begin their process. Watch other trucks as to how they are routing out of there, some of them can be tricky figuring out the path out and back to the roadway.
If anyone else has tips to add for newbies to learn from please share.
- You may be prompted with entering a club number, this typically applies to truckers getting credits for shower use, savings in the store, etc. SKIP this
- You'll next be asked for Tractor, Refer, etc. Choose TRACTOR - this is the Diesel you'll pump
- Next screen will likely have DEF on the lower left. If you need to pump DEF after Diesel press DEF. Otherwise press SKIP
- Now you'll go through prompts depending on your card asking for a Control Number, maybe a Driver number, etc. and you just have to work through these
- You may see a cash back prompt, I have only seen this with the TSD card probably because it is treated as a debit card, I think
- Once done, you'll see Authorizing Diesel and you're ready to remove the giant green nozzle, raise the handle, and pump
