Question Now what? Can’t shut engine off
TJ&LadyDi
RVF "Dinosaur"
Washington State
We have now had two instances where turning the key off...and even removing it...wouldn’t shut the engine off. Cycling the key 10-15 times finally shut it down. Tried several restarts and it works...right now.
Bad ignition switch or relay? Called Newmar and the said “call Spartan.” Called Spartan and they had no idea. They said call a Spartan shop in Missoula. That shop said “too busy to look at it.
If it isn’t one thing, it is another. Anyone else had this happen? Cause? Fix?
Is Cummins in any way connected to the ignition "circuit" for service? In other words can they look at it if Spartan can't? FL?
Sounds like a bad ignition in that the key position seems to mean nothing.
Sorry TJ, bummed yet another something!
That’s a thought, but of course it is Friday. These things don’t happen on Tuesdays.
This may be the last straw. Kinda wish we’d stuck with the simpler Class C. Wanna buy a Mountain Aire...and a lot in Polson?
Does it have a pellet grill? ?‍?
Hang in there. You are certainly making me think of never letting go of the Ventessex!
Bad or weak fuel shutoff valve or relay? I had it happen on my previous coach 5 times over a 2 week period. The only way I could kill the engine was to disconnect the negative chassis battery cable. Since I was headed home, I was going to wait until I got home to put it in the shop but for whatever reason, it never did that again. I had it another 5 years and 40,000 miles.
TJ, is a mobile tech an option there? That’s been the most responsive option in my limited experience.
Thanks. I hope ours does the same think.
It might. If things hold off for a couple of weeks, we’ll ask Premier RV services to take a look when they do the scheduled awning replacement.
It is the nagging uncertainty that keeps us on edge.
I hate that! I’d rather have ice picks in my eyes than worry about a mechanical issue causing issues for the family.
It gets better…or, worse! Coming through Coeur d’ Alene, we had one of those unexplained adaptive cruise control hits. The ”check engine“ light is now on and the regular cruise control is disabled. I called both Newmar and Spartan; they pointed the finger at each other. I then called Cummins in Spokane and was told to leave my number for a callback. It never came. I finally called their after-hours number and got connected to someone. The best they can do is to have me come to their shop at 7:00 am Monday morning.
We’re in a KOA near Spokane, but they were full for the weekend. Because we are regular customers here (and, we know the owner), they have found us a site for the weekend, though we have to change sites each day. That will work.
My patience with this coach has worn very thin, as has my patience with the response I got from both Newmar and Spartan when I called. Right now, I am strongly inclined to get all the current issues fixed and put the coach up for sale. I’m just tired of dealing with problems that shouldn’t occur on a three-year old, half-million-dollar-plus coach. And, I’m really tired of dealing with Newmar!!!
Newmar has never been a help with chassis issues. Never.
Adaptive cruise is going to be a nightmare to diagnose because it is a newmar coordinated feature with spartan/freightliner not taking ownership.
The fuel cut off is going to be a $5 relay, and is very easy to swap out. If you make it to Polson and want a hand I can come down there and help you with that. Won't touch the adaptive cruise.
Thanks for the offer, but currently we are headed away from Polson. We’re going back to Washington state for a few days, then to Oregon and then back to Polson about July 1. Right now, we are in Spokane Valley, Washington.
Can you tell me where to look for the relay? I’m thinking that is a pretty good diagnosis. Knowing what to look for and where would be a big help.
The Cummins service center in Spokane is also a Spartan 1W (warranty repairs) service facility. We now have an appointment on Monday morning for them to check codes and diagnose the issues. This should all be under warranty AFAIK. If not, I’ll drag out the checkbook.
The relay should be in the rear service area near chassis battery. It will control a push rod in the fuel rail that will shut off fuel delivery.
If you have an electric only hi pressure fuel, operating the chassis disconnect switch should also cut the engine. Some engines have a mechanical pump and electric primer, so battery is not required to keep running. Shutting off fuel is the only way to reliably kill a diesel.
Sorry to hear about this @TJ&LadyDi. I hope it all gets settled pronto
Doesn’t Spartan have a recall out on their high pressure fuel rail? Could this be related?
We’ll be at a Cummins/Spartan facility bright-and-early on Monday morning (OK, so maybe not “bright”) to find out what’s going on. That’s certainly one of the questions I will be asking. The fact that there are several things going on causes me to wonder if it is a fuel rail issue, however. We’ll see.
Here is a copy of the recall.
Newmar Corporation (Newmar) is recalling certain 2017-2022 Dutch Star, 2017-2019 Mountain Aire, 2019-2021 Ventana and 2021 New Aire motorhomes. The sealing washer may not seat correctly in the pilot bore holes, allowing the high pressure fuel rail assembly to leak. The potential number of units affected is 1,294.
A fuel leak in the presence of an ignition source increases the risk of a fire and serious injury.
Remedy
Dealers will inspect the rail threads, and replace the rail as necessary, free of charge. Owner notification letters are expected to be mailed July 19, 2021. Owners may contact Newmar customer service at 1-800-731-8000. Newmar’s number for this recall is Cummins 21E-032.
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153).
Would it look like this, @redbaron?
Answered my own question by looking up the part number. That’s the “backup alarm.” There are a couple of other suspects in the battery/filters compartment. I’ll see if I can get part numbers off of them.
