Good TPMS?
Rbjewell
Naples, Florida
Airstream
Pottery Barn Edition
28'
N/A
N/A
8,200 Lbs
I am looking to purchase a new TPMS system and want to get one that will accommodate the Motorhome and the Toad. I have one now that I paid about $100, got a repeater and it only works right over the rear axles. I need one that will accommodate my 6 wheeler motorhome and my Jeep Cherokee Trailhawk. Thanks in advance for your input.
We use the older version of the EEZ Products TPMS. It has worked well for the RV and the Toad. Easy to switch between just the RV alone and when towing.
It has saved us a few times.
Just a side note, we switch to metal valve stems on the Tow Car. The TPMS sensors move around due to centrifugal force with Rubber/plastic valve stems. We had one fail on the last trip. What a royal PITA.
This is the system I have used for years:
The repeater helps to make sure all the sensors are quickly picked up on my 8 wheeled rv + the four on my Jeep toad. Do not get the flo-thru sensors. Stick with the standard screw on sensors and remove the security covers. This makes the sensors much smaller which seems to eliminate the problem with having to change valve stems from rubber to steel.
This setup has been trouble free for us for many, many years now.
I was a user of TST system since 2008. It works well, especially with the repeater.
I do not like the new screen, but there is nothing wrong with it...just prefer the original screen.
I do not like the pass thru sensors--get the button type.
I recently changed over to another system because I had to start fresh. It works as good as the TST system, and is 1/2 price. Bonus--life time warranty !
If you have multiple trailers and multiple towing vehicles, you will find that order multiple of the 4 packs for $199 is the cheapest way to do it. I have 5 of these kits now, and every trailer and every towing vehicle is setup to monitor.
Thanks for the info.
This looks great. Wonder if there are range issues with toads
TST 507 is a fantastic system! Not the cheapest, but probably one of the best! Mine is quite accurate! Two sensors are off by one pound. The other eight are the same as my digital tire pressure gauge!
I would recommend the standard sensors, as the flow thru sometimes tend to have a slow leak!
And with my 38' coach, I do not use, nor need a repeater! And it will pick up the toad sensors at a distance of 40', while inside the garage!
I haven’t had any. @VTPete also has it. There is a 50’ antenna lead that I ran through the basement and it stops in the last compartment right before the drive tires. That picks up the TOAD tires for me
I use TST, all are flow throughs except on the inner dually tire stems as they don't seem to work well there with longer valve stems (weight). I would not get flow thru's again, easy enough to just twist them off and they are lighter. I do use a repeater in the half bath on my 40ft motorhome. Works great, highly recommend, I have no experience with others.
Thanks, what are flow through’s? I am familiar with the ones that you screw on after filling.
It is a type of TPMS that allows you to connect to a schrader valve on the end of it to fill your tire without having to remove the TPMS sensor.
And like everywhere else, they raised their prices it seems. Used to be $50 I believe.
Pressure Pro has worked well for me. I like that it works via Bluetooth to my phone or tablet vs a dedicated device.
