Soup-N-Sandwich
- May 22, 2022
Hi guys,
First time here on the site.
I purchased a 2002 Breckenridge 43 foot travel trailer for full time living about 2 years ago and haven't stopped working on it since. I'm trying to make it the best it can be with mods here and there with my latest mods being to the plumbing to prevent pipes from freezing below 10 degrees winters.
The summers and winters are uncomfortable and I feel like every season change I'm scrambling to fix the next problem before it gets too bad.
This year it's the summer heat. I installed awnings over each window (15 windows!) and window tint. This helps but not enough. There is for sure a lack of insulation which I'm going to tackle next while replacing my roof...but this air condition (Coleman Mach) NEVER shuts off during the day when the sun it shining. It simply can't keep up. The temp rises about a degree or two an hour during hot days. The air doesn't seem that cold. I just now stuck a thermometer inside the duct and the temp is 52 degrees. Is this normal? Seems rather high to me, no?
I purchased a "pierce valve" to have it recharged by a pro as it seems to run fine so I'm hoping it just needs a recharge. I believe the unit is a 15,000 BTU unit but I'm having trouble confirming this. It seems that 15K BTU is the max for a roof top unit. Could this A/C be simply too small for the space? I had the fan motor seze up last year and replaced it with the exact same unit. Fan performance is very good.
The specs of the unit:
Made by Recreation Vehicle Products DIV. of Airxcel inc. Wichita Kansas
Model: 833588914 Serial:020207838
Refrigerant Charge:
Type: 22 Oz: 17.0
Design Pressures:
High side: 324 Low side: 150
Compres. LRA: 71.0
Compres. RLA: 12.6
Fan Motor: 1/3HP
Fan Motor FLA: 13.2
It's a 20amp 120volt unit
Any feedback would be much appreciated.
Thanks very much guys.
Soup
Refrigerant Charge:
Type: 22 Oz: 17.0
Design Pressures:
Compres. LRA: 71.0
Compres. RLA: 12.6
Fan Motor: 1/3HP
Fan Motor FLA: 13.2
Soup
