- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Today I performed the forced regen using this tool. I wanted to wait a few legs of the trip not only to be sure I was in a place to get help but also to see if the soot level would show something of concern other than "normal" as others have seen as I had the clogged DPF filter in Breckenridge, CO on September 5th (Labor Day). I have plugged in the tool to poke around a few stops ago but figured I should see that the forced regen worked and any ramifications while in a good place.
I don't know the exact procedure but I did read that the key should be off before disconnecting the tool. I plugged in and then started the engine, let it idle a few minutes, then went to the DPF area. Pressed the key to start a forced regen and the idle RPM went to 1000. The process took an hour and 15 minutes so you better be sure your neighbors won't mind as it is annoying. We're not that close but it concerned me. At the start of the process the regen light came on as well indicating it was performing a regen. At completion all lights are out. I will restart later to see if there are any surprises. Can't say this was a feel good procedure, we all want things to just work and certainly don't want to cause problems. But I need to build confidence in this after the little bit of RV trauma when derated and stop engine situation but the goal is to avoid that again. I believe in my chassis and engine so hope never to see that issue again but I will perform a regen probably at the beginning or midway into a trip but don't really see doing this at an interval such as monthly, etc. We'll see. Here are a few screenshots but I'm happy that this tool worked as advertised. Thank you @Rich W. as this could save a tow, hopefully (knock on wood).
Prior to starting regen:
regen started, not showing dosing yet
now showing dosing
completed 1:15 later
now showing dosing
