- Dec 27, 2019
- Virginia
- DSDP 4326
- Freightliner
- ISL 450
- 2023 Winnebago ERA 70A or 2016 Lincoln MKX
I'm guessing it will clear on it own after a few starts or should I try to clear the code. I didn't see this code in the library on the Diesel handheld laptop.That’s definitely the High Exhaust System Temp lamp. You’re good.
The last time I checked a couple hours after regen (3PM central) it was still on. Doesn't matter if you start the engine or not. I'll check again in an hour or so. 7pm it will be about 6 hours after regenWhat do you see when you start the engine now? Are all lights out?
I was getting concerned also thinking something might be wrong or I was suppose to stop the regen after an hour. I called tech support. The senior diesel mechanic that the tech talked to said there was no set time to complete the regen. He stated it should take between 1 to 1 1/2 hours. He also said the truck they do their testing on takes a little over 1 hour. He also said the 1050 degree temperature was normal.What gets my attention is the time it took for your regen, that to me means your soot level was higher than "normal" and it's good you did the regen. Maybe try another regen? Mine took two. We really need to get better numbers on soot level, maybe @Rich W. can work with Diesel Laptops to get that in an update???
I would use the code reader to clear the code and see if it returns. Chances are it wont. Also An hour and 20 minutes is about normal for my regens. Also 1050° is a good regen temp.DPF regen completed 1 hr 20 minutes. After cool down I now have the amber engine emblem light. None prior to regen. SPN 5862 Aftertreatment 1 SCR intermediate temperature. Status Active FMI=3 . I think this will clear after several engine starts, but not sure.
Its on my list of things to do, calls to make. I’d like to know what “normal” is (the range), what levels constitute low and high, and how these would be represented on the device.What gets my attention is the time it took for your regen, that to me means your soot level was higher than "normal" and it's good you did the regen. Maybe try another regen? Mine took two. We really need to get better numbers on soot level, maybe @Rich W. can work with Diesel Laptops to get that in an update???
The code was still showing this morning. I cleared the code and started the engine and let it run unit air tanks filled the code didn't return. I cleared the code with the Diesel handheld unit.I would use the code reader to clear the code and see if it returns. Chances are it wont. Also An hour and 20 minutes is about normal for my regens. Also 1050° is a good regen temp.
Did you ever decipher what the code meant? Did I miss that?The code was still showing this morning. I cleared the code and started the engine and let it run unit air tanks filled the code didn't return. I cleared the code with the Diesel handheld unit.
I did but didnt want to post it until it cleared:Did you ever decipher what the code meant? Did I miss that?
