Problem Round 2. ding ding
lostinfla
Professional nobody
Dutch Star
2026 Willys 2 door XR
So while cleaning up rat droppings and taking everything apart that I can to vacuum up debris, I find the bedroom slide gear box broken on one boss. I checked the other 3 nuts and they were loose, even though I had installed hardened studs with locktite and self locking nuts. Called Newmar and the unit is over 1k$$. I tightened the other 3 mounting nuts and it isn't moving when using the slide.
My questions are: Should I just check the bolts every month or so and hope for the best so I don't have to part with that much cash? (maybe JB Weld)
Is there another source for that box besides Newmar?
If I do replace it, how much of a job is it?
Again, Thanks for any help and info on this.
Besides a probable repair, I would put on Stage8 fastners. I did last year and have been happy with them.
Those are cool fasteners - based on the price they are making good money selling them.
I think that torque is breaking the pot metal of those motor mounts. The fact that @lostinfla said the other 3 were loose compounds the torque problem. Not sure how large the BR slide is but I would definitely be checking the full wall slide brackets.
What is the access for the drives? are there removable panels under the bed? I assume this is accessed from inside the bedroom as opposed to basement access? I am just getting to know the coach and would like to start doing a little QA on things like this. I now have 120 hours on the rig and I want to do 100 hr inspection and service on it just like I maintain aircraft. Thanks for any info you are willing to share.
EDIT I just poked around on You Tube and found the access as well as procedure for annual inspection and torque of mounting hardware. I like the idea of using the stage 8 hardware as well.
I installed stage8 on both slides. Did this the first week of ownership. Install on the kitchen slide was easy. Bedroom slide gave me a back and neck ache that lasted forever.
So is there a stage 8 kit with the straps shown, or are those custom made for you? I see lots of different applications available online but not those straps for the gear box mounts.
Thanks
You need to verify the size required, as there are 2 options.
Thanks for the fast reply, I found them as well and then erased my posted question. I will check mine in the morning and make sure that they are not already installed. I wonder if the late modle (2022 23) have Stage 8 hardware installed by Newmar?
No, Newmar does not install these at the factory. They don't even use loctite on all builds. My 2019 had loctite, but my 2022 didn't.
Think I'm going to clean that up and try JB Weld along with the Stage8 hardware. If it won't work, I'll have to pay the price. Has anyone here replaced that gearbox? I'd like to know what I'm getting into.
It’s an easy replacement. Be sure to torque the thrust bushing to the proper manufacturers spec. though. Torque wrench with a stubby open end wrench adapter needed.
Looking at mine, I'm guessing it disconnects at the two bushings either side of the gear box, but it would need to have enough room to slide and have the coupling on the left in the picture clear the bracket. How does that happen when it's also in line with the other end of the shaft? Looks to me like it's captured between the two output shafts, and I don't see them moving. Also, does anyone know the torque and (I'm assuming crows foot adapter) size?
That is an interesting setup that I haven't seen. The motors I've seen including @Richpatty's photo above typically there are bolts going INTO the motor.
I had replaced the bolts with studs and locking nuts thinking it would make the assembly stronger. They can be removed which I will do when the Stage8 hardware gets here. I think I'm going to try JB Weld first and see how it goes. Hopefully 3 good bolts and one repair will suffice. I need to adjust the amp/shutoff setting for the slide. Anyone know how to do that?
