Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I think the key word is restricted. That is not a regulator, hence the reason I have never used one.I wish someone made a water pressure regulator that would adapt to changing pressures. Each campground I end up having to adjust the pressure or swap to a different regulator in order to get consistent pressure in the coach. If I understood fluid dynamics I would love to be able to invent one that actually works without causing a negative impact on volume.
