Also , there is a procedure to perform called a "Cam/crank sensor correlation relearn" procedure.
It wont run if there are active misfires happening
But , you will want to do this procedure if your coach has any miles on it at all.
I have seen 496 set misfire codes because of cam/crank correlation problems. Kind of a catch 22 there sorry
Post your code
Then probably on to the intake gasket.
If it has an intake leak , it is wacking the fuel trim ( adaptive strategy ) all over the place so....
Post your code
