rvpacer
- Oct 9, 2024
- Olympia, Wa
- Dutch Star
- Spartan
- 450 Cummins
- 2004 Chev Trailblazer
Thanks for the responses. I have done all those things suggested. I pulled the coach in my shop the other day and left it dry out real good. Then I put the slide out, drivers side, put my ladder up against the front side and got up there with a flashlight and water hose to see what might happen if I sprayed water over top of the slide. YAHOO !! I found it. There is a long channel that the slide out fabric fits into. This channel is in 2 pieces, being butted together right behind the bracket about the dining room window. There was a 1/8th inch gap in that joint and the water was pouring in there onto the top of the slide out. I sealed it with Flex Paste and now it is fine.Usually when you drop the jacks the water comes off before bringing the slides in. If you see water draining just wait a bit before starting up and bringing the slides in.
@rvpacer ... any chance you can post a picture of this? I have struggled with this issue on ever Newmar coach I have owned with a FWS. Maybe I can finally fix this as I hate to even have it rain when traveling.There is a long channel that the slide out fabric fits into. This channel is in 2 pieces, being butted together right behind the bracket about the dining room window. There was a 1/8th inch gap in that joint and the water was pouring in there onto the top of the slide out. I sealed it with Flex Paste and now it is fine.
I'm trying to attach a photo of the problem before I sealed. You can see the gap and it goes down over the leading edge also , you need to seal it all.@rvpacer ... any chance you can post a picture of this? I have struggled with this issue on ever Newmar coach I have owned with a FWS. Maybe I can finally fix this as I hate to even have it rain when traveling.
FLSteve
Thanks ... I will now get up there and see what mine looks like.I'm trying to attach a photo of the problem before I sealed. You can see the gap and it goes down over the leading edge also , you need to seal it all.
