Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
That’s what I have but they have lost their grip. Won’t clamp it shut all the way. Might try again when I’m at a better place.
Curious if everyone shuts off the Oasis manually in the basement when not in use.
Whenever we get off the road and put the coach in storage, I power off the Oasis using the power button on the unit itself. I do this as a preventative measure in the hopes that it actually powers down the loop pump(s)
Since some of the oasis is 12v, it may not even shut it all down with the breaker….?Didn’t realize there was a switch on the oasis.
The couple times we did shut the Oasis down I did it with the circuit breaker.
I’ve seen it but never considered it until this threadDidn’t realize there was a switch on the oasis.
I haven't tried to shut it off in the basement. However, I have learned that if I turn off the salesman switch and turn off the chassis batteries, the Oasis unit will still continue to turn itself on when the temp of the glycol drops below a certain temp. I now turn off the Oasis from the SilverLeaf panel (burner and AC elements) when in storage to stop its constant cycling.Curious if everyone shuts off the Oasis manually in the basement when not in use.
Whenever we get off the road and put the coach in storage, I power off the Oasis using the power button on the unit itself. I do this as a preventative measure in the hopes that it actually powers down the loop pump(s).
I also manually unplug the camera controller to cut the power to the cameras, and I installed a power cutoff switch on the dash to kill power to the Xite system (after replacing both screens once already).
In my conversations with various vendors, it seems that Newmar has all this stuff wired up to run nonstop and that contributes to the failure rates.
