- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
@redbaron I'm struggling to understand this. From what I can find FusionHub Solo is for one Peplink device. What if you have two Pepwaves such as me?
I also don't understand the bonding. Let's say as I have AT&T and Verizon, one may be and usually is better than the other. How does the weak player play into the equation and help in any way over a connection to the strongest source?
It seems you need some type of virtualization to install this so it must be a self-contained OS? Not sure if I could install this straight onto a Windows server without the need for Hyper-V, which I have but prefer not dividing up existing server resources, or Ubuntu server I also have.
With a single pepwave with one radio per pepwave, I'm trying to figure out how this works. I assume it's going to bond WAN connections so any WAN you can add to the mix will "bond" but again, just curious how this benefits my speed over the strongest WAN provider.
If a license is required, where do you get it? Even if free? Is this restricted to one Pepwave?
I believe there are different terms at play here. SpeedFusion and FusionHub?
Edit: reading the docs, I see VirtualBox would be an option which I've used before.
