goldsky
- Jun 23, 2021
- Rowland Heights , Ca
- Fleetwood American Dream
I have a 1999 American Dream Motor home with an 8.3 Cummins ISC caps Engine 133000 miles on it
And it is turning in to an American Nightmare.
Maybe somebody familiar with this Engine has some ideas.
Any help is appreciated.
Engine is loping/hunting on idle, black smoke runs bad and has weird noise coming from muffler. Had a few mechanics advise me what to do, but it not help much. Did a lot of work and replace parts, but it is still doing it.
Here is what I did so far.
Replaced fuel filters, replaced fuel hoses from tank to filters. Checked air filter ,replaced Injectors. Installed Fass lift pump. Replaced high pressure pump with Cummins rebuilt, That made it smoke less, had Injectors that I replaced rechecked, removed timing gear cover checked timing marks, removed and checked Muffler and exhaust brake. Checked Turbo, spins freely, no oil leaks. Replaced Cam sensor and speed sensor. Replace map sensor, pressurized intake from turbo, no excessive leaks. Checked Valve adjustments numerous times does not change, checked compression 400/420.checked exhaust manifold no visible cracks
Check engine was on before I replaced the hp pump, but now no more check engine light.
One mechanic suspected that it was a slapping piston, but with good compression and no blow by, it seems unlikely to me.
Below is a link to the Video.
Below is a link to the Video, Notice funny sound from muffler.
