AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
Sound like a bad cell. Disconnect the ground on your fully charged bank and let sit again, that will tell you if it is the bank.How far are your batteries down after sitting for 12 hours or so with nothing on?
It seems that 600 AH of useable power should last for days, yet overnight my batteries are down to 12.0 v. I did not even turn on a light for more than about five minutes.
Newmar says it isnormal. I load tested each battery Voltage on all are goid. They say parasitic draw. I say 1200AH - 600 useable. Should notbe that much drawing on battery, inverter res. refrig and chassis? Six 200AH 6v batteries. 30 A draw shouldlast At leat ten to twenty hours, or am .i missing something. Those items should not be drawing that much.Sound like a bad cell. Disconnect the ground on your fully charged bank and let sit again, that will tell you if it is the bank.
How long has it been that you replaced the bad battery?Newmar says it isnormal. I load tested each battery Voltage on all are goid. They say parasitic draw. I say 1200AH - 600 useable. Should notbe that much drawing on battery, inverter res. refrig and chassis? Six 200AH 6v batteries. 30 A draw shouldlast At leat ten to twenty hours, or am .i missing something. Those items should not be drawing that much.
Did replace a bad battery. It went to zero on load test.
Don’t know that much detail.The write up is good! Do you know if the plates are pure lead? I see they offer a great warranty.
