Same here, hearing aids, wife bought me Bluetooth headphones, they work greatOk mystery solved. No magnets. Vertical brackets(2) directly into TV. Horizontal bracket mounted into wall at top of T.V. T.V. hangs from top(clips over) horizontal bracket. Remove the 2 screws from bottom of vertical brackets. T.V will hang from top so no need to have any help holding. Lift T.V. upwards holding at bottom. It will be free. Pull power plug. 2 HDMI’s and unscrew CATV coax. Then it is all yours. Needed to clean back there anyway and connect to optical port for better sound. Actually to stream to my hearing aids. Sucks getting old. But beats the hell out of wife yelling at me to turn the T.V. down. Thanks for all the input it helped solved the problem.
