sheridany
I prefer and use these from the RV Water Filter Store:
Brass Quick Connect, 1 set
Check out the deal on Brass Quick Connect, 1 set at RV Water Filter Storewww.rvwaterfilterstore.com
Tried the less expensive garden hose quick disconnect fittings and they leaked badly. YMMV
Actually, I need to remember to take my pressure regulator off the spigot as I leave. My quick disconnects are on the hose and output side of the regulator that screws onto the spigot. So far, I haven't forgotten, but have had a couple of near misses. It helps when you have a detail-oriented co-driver like LadyDi. She has saved the day more than once.Just have to remember to take the disconnects off the spigot as you leave![]()
I have a couple of places that need 90 degree quick connects, and these work very well..
Kwik Link Quick Connect System, 90 degree
Check out the deal on Kwik Link Quick Connect System, 90 degree at RV Water Filter Storewww.rvwaterfilterstore.com
Ditto! I like the Kwik Link. I also have some brass ones that I got from Amazon and they work well too.I have a couple of places that need 90 degree quick connects, and these work very well..
