J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
I was kidding I'm sure you know @DKRITTER but it is interesting. I don't feel comfortably leaving anything connected to the black tank rinse that has a path to my fresh water system. I'm trying quick connects like others, doesn't mean I will stay with them either but for now they are working well for me.
Must be a Ventana thing; it works great on the MADP.I saved up my allowance and took the money out of savings and finally bought one of these 90 degree kwik link 90 degree quick connectors for my black tank rinse. Well, seems that nearly $30 of hard earned money is wasted. I went to install it today and the twist knob contraption Newmar uses on the black tank rinse is in the way of the quick connector from the hose connection. Looks like this is not going to work.
Kwik Link Quick Connect System, 90 degree
Kwik Link Connect System - 90 degree Attachs to your RV's water inlet for faster hook-up and a leak-free connection. Premium construction with high grade molded plastic body and aircraft-grade anodized aluminum connector, they come with a Parker female coupler, a dummy plug to protect hose end...www.rvwaterfilterstore.com
Before you return it.,Did you watch my video that is posted earlier in this Post? If you have the same fittings as the ones in my Newmar, you have to position the fittings very carefully.I saved up my allowance and took the money out of savings and finally bought one of these 90 degree kwik link 90 degree quick connectors for my black tank rinse. Well, seems that nearly $30 of hard earned money is wasted. I went to install it today and the twist knob contraption Newmar uses on the black tank rinse is in the way of the quick connector from the hose connection. Looks like this is not going to work.
Mine is the now-discontinued (apparently) 105-degree version; angled out.Can't tell if the bottom of your kwik disconnect is angled out, mine goes straight down.
