Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
I've never even thought of that before and both my water tank and fuel tank are up front. 100 gallons water full and 130 gallons of diesel full when I leave. I just took for granted it was engineered to handle it.One thing I would caution about is how much the water tanks adds weight your coach. You do not want to be over the weight limit, particularly on your steer axle. Just be aware of it if you have not done a four-corner weigh.
Did the nexlink work for you? Code gone? How do you know when your coach is doing a regen? Newmar did one last year as part of maintenance for us.Yes, my coach does regens automatically, how often I can not say I never kept notes on it but if I'm on a 3 month trip moving around every week I bet I see 3 or 4 regens. It might be less if I run in 5 gear. Spartan recommends that to get the temp up when running down the highway at 65MPH. In 6 gear I'm at about 1,700 RPM and 5 gear about 1,900+. I did get the Nexlink tool so I will try that and see if the code goes away.
