- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
On my last trip, 7700 miles, I added a jug whenever my dash indicator read one dot low. There was always room in the tank for 2.5 gal and I was constantly adding fresh DEF.
Since mine is an earlier model with a mechanical float in the tank (2015 chassis and before) I run the risk of gunking up the slide mechanism for the float, getting false readings, and encountering DEF header codes/issues/derate.
So I keep mine full and fresh. Its another benefit of using box DEF - I always have some in stock, it only takes a couple minites to add one, and I can do it at me leisure, usually in a CG. But I also get 300 mpg on DEF. If it was 100mpg, as with an ISX for instance, I‘d probably approach it differently. Also if I had a solid state DEF header.
