Resolved Broken Key - Help!!
Go back to the dealer and buy the cylinder that matches the key!! It takes 5 minutes to change it out!!
Another option take a price of bailing wire use a drop of super glue on the end, hold it on the thickest part of the key, allow it to fully harden and then try to pull it out.
I know you’ve solved your issue, but believe it or not this morning I went to open one of the compartments with the exact same 391 key and it broke!
I was going to try to use super glue to get it out of the cylinder but instead I tried using the wife’s stitch ripper!!
I slid it in the side to and it moved the key on an angle, I then took the point and pushed down on the top and was able to pull the key out!!
just an FYI!
Except..."what's a stitch ripper" ?
