Check your tires every travel day!
This is total hogwash! Do you have any actual data to back up your claim?
Or is it another "I saw it on you-tube" fact. :whistle: I've seen those videos of some yahoo destroying a vehicle with a pressure wash but he used an industrial pressure washer, not your average home pressure washer.
No. Many years of hands on experience. ASE Master Certified, and tons of projects under the belt. Most of which include powerwashing as prep to dig in and do more. One of my favorite tools in the shop.
Wow, shocking to look at for sure. It looks like it may have been a Newmar from the basement doors and latches and paint, not sure. If anyone finds any more details please post. While we can only speculate what happened I also find these RV's can get away from you in an instant from distractions in the coach whether cell phone, GPS interaction, something dropping off a counter and you want to look and see what it was, etc. These Class A's require you to be at full attention 100% of the time as you can go off the road in an instant!
Yes, inspect tires and pressures as we all have learned. Take a flashlight and look across the other side and look at the insides of the tires from time to time too. Tires are every Class A owner's nightmare and have been mine since day 1.
That’s why I have a Monaco. It has a steel structure welded to the frame. Yeah,it's heavier but you have a better chance of survival
I have one of the less expensive home powerwashers. If I crank the power to max and use the smallest jet nozzle, it will bore a hole in concrete. I did it as a test when I shortly after I bought it, so I know it will.
Back off the pressure and use the wide spray it cleans our rig fine.
