J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
I’m not an expert on a/c units but I’m not sure running the system every month or so would be much help. You obviously have a small slow leak in the system that will probably leak regardless. What running it periodically will do is give you a heads up to get the system recharged. If you made it six years hopefully you will be ok for several years more. Did they put a dye in the system to see if they could locate the leak?
