Dom 2652 Refrig Question
mikegray
Lagrange Ga
Forest River
RKSS
27 ft
GMC 1500 Seaira
I have a new to me 2017 wildwood 27rkss. The frig will work just fine on shore power but will not stay lite on prophane. I purged the system but no good. All other prophane items work ok. It will light for a couple mins. then goes out. Any suggestions?
Thanks, Mike
The board senses the flame thru the spark wire. It should stop sparking immediately when the flame starts. It will try to light 3 times then lock out. You can try to replace the ignitor wire as a cheap fix or get a board.
Another reason is the high temp thermal disk mounted to the chimney above the flame is tripping to easily. Pull the spade connectors off and stick them on the ends of a regular fuse and try it. DO NOT run the fridge in this way if this solves the problem, get a new thermal disk
Thanks. You can hear the spark ignitor clicking even after it starts up?? It doesn't stop until the gas goes out.
Mike
