Desertboyz
- Oct 6, 2020
Thank you John. I needed some instructions, so I know what to do and if I needed any special tools ?I’ve done it several times. Young kids like to flush wipes.
It’s really easy to disassemble and not actually a terribly disgusting job. Much cleaner than any house toilet I’ve ever disassembled.
- Disconnect water to coach
- Turn off water pump.
- Flush toilet once or twice to drain water (some will be left but not much)
- Put down some old towels on the floor in front of the toilet
- Remove the two screws holding the toilet to the floor
- Gently slide the toilet forward a few inches so you can get access to the rear connections
- Disconnect drain line by loosening oeticker clamp and pulling up on drain line
- Disconnect waterline by loosening oeticker clamp and moving line over to open drain line and letting water run into drain
- Disconnect power
- Flip toilet onto face on towels to catch any water from bowl
- Remove macerate by loosening Velcro strap and pulling two halves apart
- Clear obstruction and perform steps in reverse order to reassemble.
Took me an hour the first time I did it as I went super slow. 20 minutes the second time. I bet I could do it in 15 now.
@MapNerd, you didn’t glue anything together during reassembly did you? Excess glue could cause slow drainage of your tank. ???I’ve done it several times. Young kids like to flush wipes.
- Disconnect power
