I moved my Easy Start over to the new unit. (Dometic Freshjet 5) It started the first time with a 30A surge. The last one was 15A. It runs at 12A...So LRA is only 3 more amps. Amazing contraption. I'm hoping they offer an Inverter friendly unit. Australia is installing Dometic Freshjet 7's. They are making them for the Campervan community. Problem is they are 220v...and they require an Air handling unit for now.... where the controls are located. Maybe they will refine the product for the US market.Yeah, umm, nope. This is going to be an expensive trip to Newmar when one or both fail. I'll have both done at the same time, not gonna be cheap I'm sure. Ugh!
Will you be installing Soft Starts in thew Coleman(s)?
Thanks for all the info. From other posts that I’ve read on the subject, I thought using the existing RJ11 cable and adding a RJ11/RJ45 adapter would work. Wondering if you have any insight into this?The hangup I have with Dometic is the running of RJ45, for Heatpump Freshjet 5's. Easy to pass thru the plenum for the run between units. I can imagine the thermostat and AGS will be a problem. And I have no idea if the new control units will continue to support Auto Gen.
Not that far back (except the one still on my batwing antenna)...but I still remember black switches good for 250,000 cycles instead of touchscreens.Remember when there was a capsule of mercury and when it tilted one direction it closed a circuit and when it tilted back the other direction it opened? I'm glad we simplified it.
Chuggs, I am not seeing anything about heat pump capability or optionality on the Dometic website. Where are you seeing this?
