Question Flat Tow a Ford Flex 2019 SEL Front WD
The DutchStar is rated for 15k lbs towing, the tow hitch I believe is limited to 15K lbs (edited). The base plate and BlueOx tow bar used is limited to 10k lbs. Ford Flex is approx, 4600 lbs.
The GCWR is 67k lbs. We travel relatively light so no limits exceeded.
The DutchStar is rated for 15k lbs towing, the tow hitch I believe is limited to 5K lbs. The base plate and BlueOx tow bar used is limited to 10k lbs. Ford Flex is approx, 4600 lbs.
Im pretty sure the hitch is 10k. Actually I believe it’s 15 k Does it still have the sticker on it
Maybe confusing this with CanyonStar hitch. Did some research as best I can tell it seems to be 15k hitch.
Found it. 15k on DutchStar
