HWH Question
forget the jacks when manually leveling. Think about your coach when pressing the arrows i.e. front up or rear up, etc.
I have the exact same issue at times. I just recycle the auto level sequence and it has always self corrected.
I guess I need to read the manual again but I can never figure out which arrows to push to manually level the coach. It does not seem very intuitive to me. If there was simply and up or down arrow for each jack it would be easier to understand. I just use the auto level for now but if I wanted to raise the wheels off the ground I would need to use the manual function.
My understanding is that the ability to raise one jack individually would also allow you to tweak your chassis, so instead you can manually raise either end or either side evenly. Looking at the arrows that way they make sense.
