Impact 359 Slide Issue
Ribbit
We have a 2022 Fuzion Impact 359. When the “living room” slide is closing, the sidewall of the fifth wheel pushes away from the frame and creates a inch to two inch gap that you can look through from the stairs leading to the bedroom and see the ground. I jacked up the slide to see if it was properly centered and noticed that there are no rollers in the piece over which the slide travels. There are rollers are on the slide for the bedroom closet, however. Are there supposed to be rollers on that piece? If not, anyone know why the wall is separating. There only thing that seems to be rubbing against the slide is the rubber seal. However, the gap between the slide and the side/frame wall is greater when the slide is out than when it is in.
