- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I had a near fire situation in my 2017 Newmar Ventana motorhome but thankfully the circuit breaker(s) did their job. I noticed an electrical burning smell and then when resetting the breaker to check the situation a flame shooting out the electrical connections of the OASIS hydronic heater subsequently tripping the breaker. After a call to ITR I learned the problem was common and due to the way Newmar wired up the 120V connections to the OASIS unit. The real problem, in my opinion, is the design by ITR having too small of an area to stuff 2 x 120V lines into an area to contain the connections in which the metal edges are sharp and can strip the insulation off of the wires.
You can see from the attached pictures the problem and the burn through. It's amazing this didn't happen sooner, this was about 1-1/2 years into my coach ownership. To inspect your OASIS unit is not hard but take safety precautions. Disconnect from shore power, turn AGS off, turn both OASIS circuit breakers off. You can access the electrical connections from the bay next to the OASIS (pass through bay typically) and just unscrew the metal plate where the 120V lines go in. Remove the wires and inspect the connections, secure or redo if necessary, protect with electrical tape, carefully reinsert the wires and secure.
