Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Yup! tripp lite told you what I did, it is a modified sine wave unit. And as I said you need to test anything you will use with it. I found an inductive cook top of one brand would work using one and another would not. If you need to use the Cpap then you need truesine/puresine. It used to be an expensive item but today puresine is fairly cheap.I spoke with a tech at Tripp-Lite and he told me a regular voltage meter doesn't read the correct voltage. Tiffin has some voltage meters installed so I'm not sure why they are there except to read out when the Generator is on, or Utility power is supplied. He talked about sine waves and such but that was way over my head. What I don't understand is why the microwave and fridge work but I can't even get my phone charger or cpap cord to work on the same 106volt circuit. He let me know I could install a different Inverter that has a better "sine wave" or whatever, but when plugged into Utility power the source has to be 230 volts. Ok, now I am really lost on this...
I could tell you the reason the voltage is lower and what the difference is but I think you would be lost in the conversation as many would be. Truesine produces the same wave form as shore power or generator (Much cleaner in fact). The investment is well worth the effort & a low frequency low voltage inverter will be the most durable on the market. Your fridge if compressor style will last much longer. If the fridge is propane it will cool much better because electric heating with modified sine wave(what you have) will not produce as much heat.
Cheap items like sonic units for mouse control and bug control may burst into flame using modified sine inverters.
Don't blame Tripp Lite, They were producing inverters back when an inverter produced square waves. Blame outdated tech and the fact that only a few years ago modified sine wave was what was the most popular. You almost had to order true sine online back in that day.
