- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
@Richpatty what did you end up using to connect the batteries (cables / bars) and where did you get them? Did you build them yourself or have them made to specified lengths? Compartment looks great, as you mention, this looks like quite a bit of effort. I'd move my victron equipment in there too after seeing what you've done and get it out of the slideout bay adjacent. I assume the magnum 2812 is fine or are we losing anything with that inverter? If spending this much on 8 x Lithium batteries should the inverter be considered?OK! I FINALLY got some time (over the course of two weekends) to complete my Lithium conversion. It went pretty well, but it was more time and effort than I expected. I would say the effort was comparable to my solar installation.
The rebuild of the battery compartment took some effort. As I had mention in my plans, I removed my battery tray, cleaned out the compartment and added 1 inch insulation and 1/2 plywood (which I painted white prior to installing). This was challenging, but it makes for a much more sealed and nice looking compartment. I ran the insulation up to the top of the compartment to seal it off the best I could. I added foil insulation tape to close it off at the top.
Summary of the changes/improvements I made (in no particular order):
- I re-used the 3/0 cables that Newmar had used for the batteries for the short connections between the batteries and and the runs between the banks of 4.
- In trying to best balance the charging and discharging of the batteries I used a method which breaks down the 8 batteries in 2 sets of 4 and has the negative and positive leads come off separate sides of the bank. I attached a picture of an example.
- I added busbars for both the positive and ground connections to make connections easier and more standard.
-I moved my Victron solar controller from the first storage compartment to the new battery compartment to make it easier to get to and also shut down when needed (my RV has a covered port which stops the solar).
- I added (finally) a new cutoff switch to shut down the 12v in the RV. This will help with parasitic loads when stored.
- I added a small (2x10) floor vent to the back of the compartment for ventilation in hot weather. It can be closed (like any floor vent) for winter. I also have a magnetic sheet that will go over it to help seal it when I want. I also have plans to put two computer fans on the back of this vent (12v) and set them to a thermostat to run when the temperature becomes warm.
- I purchased/installed a Victron Smart Shunt so I can see SOC via Bluetooth. I wired my Magnum shunt receiver to the Victron Smart Shunt (although I removed the actual Magnum shunt) so the Magnum will still be aware of (and calculate) the SOC.
- The new batteries are held in place on three sides by 1 1/2 aluminum L-bar. I also added 1/2 hard foam insulation between the batteries and the bar to make sure there are no ware points as we bounce down the road. I added insulation between the two banks of four to also avoid rub points, but also to add space for the cables that run to each battery. I also added a strap for each row of batteries to hold them down.
- I will be installing a Lithium BIM in the next week or so as an insurance policy. I am not really worried about losing any charge time from the alternator (due to the Li-BIM) as I have the solar to depend on. Also, the Lithium's charge pretty quickly, so you would not have to be on shore power or generator to top them off.
I think that is it... I will post something else if it comes to mind.
The finished product is below.
I am glad it is done!
Rich
