Nitrogen in tires
As many of you know, I have a few really nice sports cars. I have had BMW's for 20+ years, and until this year the BMW dealer always used Nitrogen. When I purchased my latest M3 it came from the dealer with Nitrogen. Earlier this year I purchased a new Cadillac CT5V Blackwing, and it did not have nitrogen. I was a little disappointed, as I had always had nitrogen in my sports cars. I assumed that the crazy American's just where not as advanced as the Germans, so I took my Blackwing to the BMW dealer and asked for Nitrogen.
My rep was more than happy to fill it with nitrogen, and didn't even charge me, but while doing so he said that BMW USA has dropped the nitrogen requirement for all cars, including the M, as their data has shown no benefit from running nitrogen.
I personally see the benefit of not having to add or reduce air as the seasons change, but the automotive industry is moving away from it. I am not sure how Porsche is going to change, but my guess is they will continue to fill for a while as they began the trend for the sports cars.
I decided that it wasn't worth getting nitrogen tanks at the house, so I am now going back to 78% nitrogen for all my tires when they need it.
Exactly. I have a small compressor for filling tires. I mean, I got it for bicycle tires, but it works well on our cars. I check the tires regularly and fill them as needed (maybe three times per year.
I know it's difficult for some people to admit they've been paying for something that is absolutely worthless for years.
All I'm asking for is some actual data to support the claims of extended tire life using N. There seems to be only anecdotal evidence.
Otherwise I'll stick to 78%Nitrogen from my compressor. :whistle:
Testing conducted independently by Consumer Reports and the National Highway Traffic Safety Administration shows that the benefits are more theoretical than practical.
Did he pull a vaccuum on the tire to remove all of the other gases before filling it with nitrogen?
They pump them down to zero on the tires that I added air to.
Yet another reason I don’t want to try to do this at home, it’s not normal to have a pump to pull the air out and I don’t want to buy one.
What the hell!
Quick calculation:
Volume= original volume (at 1 atmosphere,or your elevation)*(original volume/final pressure)
Zero volume would be impossible to obtain without a vacuum chamber due to the inability to hold a seal! However actual volume of O2 in both nitrogen vs air fill. At the pressure of inflation,using the formula above you can determine the actual volume of O2 in the tire.
No place that offers the service to my knowledge considers the volume at elevation pressure.
Furthermore, over time the O2 will escape the tire,just as the physics used to remove the O2 in their equipment does. You may ask if the tires will do the job anyhow, why bother? Well because the process of adding air will keep the O2 in abundant supply.
On the same principle, topping off the pressure with nitrogen, will continue to reduce any O2 that was in the volume of air during the original tire installation.
There comes a time that everything becomes foolishness, when carried beyond reason!!!
Have a good evening, and don't lose to much sleep over this!!!
What the hell!
Quick calculation:
In post #42 you said that was your last comment on this subject, yet here you are. ;)
Carry on.
How would they keep the bead seated while doing that?
The pumped it down but there is no way they removed all air.
Thinking about this, even mounting the tire will introduce 22% oxygen that will be diluted with nitrogen.
The more I think about the use of nitrogen the more I am convinced it’s not practical or beneficial.
From Goodyear website
“Some tire shops feel that nitrogen is an important feature to provide to their tire buyers. Besides the cost of acquiring the nitrogen, there is more labor involved in filling tires properly with nitrogen. To remove the regular air from a tire and fill it with nitrogen requires a “purging” process where the tire is repeatedly filled with nitrogen to gradually remove as much of the regular air out of the tire as possible.”
According to Consumer Reports benefits of Nitrogen filled tires, in practical terms, are more theoretical than real.
So Joe!
When you were young did you fit in? Or were you ridiculed? My guess is you had few friends! Take heart My friend, if true, your not alone, but rather the universe is full of your family!!!
Anyhow, what you posted is as is expected, full of agenda speak! This is what I read!
1) the choice is based on cost, and convenience!
2) products disappear from shelves, for much the same reasons. (Profit)
3) if we test properly, we will serve our real customers needs, while appearing to serve the public!
Let me explain!!!
Anytime a word or concept is repeated 3 or more times it is marketing!
Just because a product is no longer on your favorite store shelves,does not mean the product is no longer made, or available.
Now the biggest point!
a) to produce the highly reactive ozone,you need the friction that only use will provide. Putting the tires in the sun will only react on the outside of the tires, where those "normal people" expect ozone damage! Notice the 10 year carcuss life pointed out for unused tires!!! Does that corelate to common practice,and recommendation??
Tire resistance (MPG)!!! The least resistance is produced with a new tire! Yes the information is in the report, and passed over! As the ozone reacts with the rubber compound, the compound becomes more brittle (that's the information). This creates friction,that comes from resistance, that creates more heat, and that heat comes from someplace! That is noticable in MPG. The weather cracks that you see in an old tire actually offers better MPG due to the air gap offering a point of least resistance!!!
Like you said Joe! Purging is the way to reduce O2 in an install! That is how a new propane bottle is prepared for a fill. That only need be done with one purging fill, and only requires low pressure!!!
As far as who the sponsor of the project??? Well first why this article is so timely! Online tire sales, would have to downplay the importance of nitrogen fill,and tirerack would gain from such propaganda!!!
And yes, there is always an agenda!!! And you, Joe are less susceptible to the propaganda, because you always research!!!
So Joe!
Let me explain!!!
So you don't get the motivation issue I stated in my last post?
That's ok,most don't!
This is the thing. This topic is not that important to me!!! It will prove of little importance to others in a short period of time!
The riddle to these topics I involve myself in are simply to waist My time.
I could take the time to explain AAAs motivation, but I'm not going to.
I spend my time when not here learning from people like Clif High who have very good insights.
but all this time spent, is only in waiting for my family to arrive!!! I don't really see how this information will help anyone in the future world!!!
