Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Thanks for the update!
Hello Kevin D. I wonder if you could help me with a water issue? We have a wonderful 2011 Heartland Big Country, currently staying at a park in AZ. It appears while on city water connection, water pressure is somehow bleeding over and filling our fresh water tank to over fill and leak out. I have turned off the city water and just using fresh water pump for daily use. Could this be backing up through a faulty water pump? Thanks for any help, Ivan W.Thanks for the update!
Yes, it does continue to send water to the fresh tank when I reset to city water, and yes I do turn off the pump when connected to city water. I will replace the pump when we return to base camp in kansas next week. Thanks for your guidance. / ivan w
Great idea... And I actually tend to hold
when you get the new one, don’t throw away the old pump. I had one that would run and not pump water. I removed the bottom sections, cleaned the diaphrams and re-assembled it. It worked perfectly. I carried it around for several years as a spare.
Getting ready to order a new pump. Orig equip is a Shurflo 4008-101-E65. Can I replace that with a 4048-153-E75 pump to upgrade?? Or should I stay with the orig model? Our unit is a 2011 Heartland Big Country 5th wheel.
