- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
If you have nothing to do today, umm . . .That's NOT it.That's it! Okay, sounds like you found it then.
I won't, I won't! I promise, I won't!Then there is this - pic of the horrible retro pump with 3/4” fittings
Lest you ever consider such a thing….. I’m sure you won’t. A few of us acted as guinea pigs and proved beyond doubt through the scientific method that this is a bad idea!
Mine started the “flame out” thing again on the last day of our trip. The burner for a few seconds, shuts off, waits about 30 seconds, repeats. This after just installing a “5 year” maint. kit.
So when I get around to it, I’ll open it up, see if its anything obvious, try to diagnose, and if necessary get some tech support from ITR or whatever. So something to look forward to…Leaving on the next trip in mid-December (skipping Christmas) so I’ll have an answer before then.
Yeah, and I changed the Gar Ber filter about six months ago, so probably not the problem.Did you fill the Diesel filter with fuel when you installed it?
If not, you have air in the fuel line that causes a flame out.
