lol, well put!Damn
Looking forward to hearing how this works out. Glad you rescued your coach from those guys. Do you have something to clear the code(s) when you're done or are you just going to use the ignition cycles method?lol, well put!![]()
Yes, the Ocala Freightliner shop had an "Oasis" sticker on the door, but I didn't see it until I was leaving, and by that time there was so much bad blood between everyone that it was too late. Besides, if their approach to fixing the Oasis is anything like their previous methods of operation, I will need to:@Jim do you have the DEF head simulator? If not, consider emailing keithcoyle@hotmail.com and getting one. See if you can get to an OASIS branded FL service center or whatever FL Gaffney may advise.
I have a Diesel Laptops scan tool.Looking forward to hearing how this works out. Glad you rescued your coach from those guys. Do you have something to clear the code(s) when you're done or are you just going to use the ignition cycles method?
lol, head from Keith. Only works on 2017-2023, mine is 2016. About par for the course. . .As for the DEF simulator, I have emailed Keith. Thank you!
I will say however, that the Holliday Inn Express we stayed at was the nicest hotel of its caliber that I have ever visited. Well worth the $130 a night we get to toss onto the Freightliner ordeal. The staff was friendly, the room was spotless, the breakfast bar was great and the Internet worked very well. Top notch operation and I would highly recommend it should you ever have to deal with Ocala Freightliner for anything.
- Chat with an blunt person who makes it clear they don't make appointments, so bring my rig down and get in line,
- Wait 2-days and pay a $500 minimum charge to have the system looked at,
- Spend 3 days in a motel while Freightliner orders parts that aren't available,
- Argue with the same blunt person about why they are charging me an additional $75.00 for shop supplies when no work was done,
- Drive away 4 days later, $550 lighter in the wallet and no closer to a solution than I was when I "got in line".
Jim he told me the same thing. On the bright side, he said there was less problems with the sixteen model because they're analog. I know it doesn't help. I am only one hour from freightliner Gaffney if I can help you with getting parts. Let me know.lol, head from Keith. Only works on 2017-2023, mine is 2016. About par for the course. . .
I have 3 spares onboard right now. Just have to figure out which pump is the bad one. If the bad pump had blown a fuse, it would be easy to find. But it didn't, so I don't know which pump is the bad one. Trial and error will start tomorrow!It is the summer loop by-pass and should only be left on when needing hot water. Order a pump from US Solar Pumps.
C1E Circulating Pump | US Solar Pumps 2026
C1E Circulating Pump is part of our C series micro centrifugal pumps. It is a 12 volt 20 litre pump. It is designed to be quiet, compact and lightweight.www.ussolarpumps.com
