DavidL
RVF VIP
- May 8, 2021
- Metamora, MI
- MountainAire
- Spartan K2
- Cummins 500hp
- Grand Cherokee
How did you mechanically use a stock float tank valve? Did you cut a big hole in the tank? Or did you put a secondary tank (at the same fluid level as the primary) and put the valve in there?For my automatic fresh water shut off, I went to a farm supply store and bought a "stock tank float valve" (in 2010). Cheap, easy and doesn't require any fancy stuff. Also easy to replace if I should ever need to. It was mounted into a Valterra ABS tank. I only use water from my fresh tank. Once it goes thru my filters, the flow was reduced to a trickle, it was better to simply let the fresh tank fill slowly and then use the float valve to shut off the water supply once the tank level got high enough.
