- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV
No idea, but with Rettroband the "evidence" is largely preserved after an event like this. Normally the tire is so shredded it is not clear what happened.Good find, good story. That's what I like seeing. Interesting scenario though. Is that a cut at the outer edge of the tire above the gaping hole?
That is why they won’t put the bands on tires that are older than three years. Their cost to replace damaged older tires began to erode their margin.One thing that concerns me in watching the removal of the RettroBands from the New Aire (video above) is the amount of torsion placed on the tire (stretching it) to get it out. Imagine that done on install causing tears, fractures, etc.?
I heard the same as a second-hand quote from the former president of Newmar.A friend told me that he considered having the Rettrobands on his Newmar would be overkill as he felt the Comfort Drive would keep his rig from diving left/right if a steer tire blew.
Does his theory have merit?
Would you clarify this for me please. Are you saying that all driver control of the steering system was lost? That would mean that the mechanical linkage from the front wheels to the steering wheel was so badly damaged that it was totally useless. Is that correct?I had no steering control at all
I have documented and am updating what happened in a different thread on rvf, but what happened was the shredding tire chewed through the fiberglass bay in front of left wheel that contained the electronics bay, and immediately most of my electrical systems went down. I assume (RV is still in FL shop repairing said damage) that this severed the controls for the comfort steer. I was in right lane at 65 when blowout occurred, no wheel protection (I had Tyrons installed but they failed) so left rim was on pavement and I had no way to steer vehicle to the right shoulder as I had planned to do. I know the procedure for a steer blowout is to accelerate, and I did try that but immediately realized I had no steering control, engine had shut down (again electrical) and was swerving into the left lane and headed for the median at speed. I got into the brakes hard at that point and attempted to stop before going fully into the median. I was able to get it stopped with rv partially in median, right rear wheels were off the ground and rv was "teetering" as traffic blew by. Recovery tow driver estimated with contour of median I had about 15 more feet and I would have rolled over into median. Sorry for lengthy post and I didn't intend to hijack this thread, but I believe the expense of the Retrobands is far less than the cost of my repairs, and hopefully wold provide some semblance of control like seen in the videos. My tire in the photos on my other post has no visible tread on it to run on, just sidewalls and steel wire shredded everywhere and you can see I was running on the rim on pavement, all things the retrobands are intended to prevent. Hope this helps and again apologies to OP for the temporary hijack.Would you clarify this for me please. Are you saying that all driver control of the steering system was lost? That would mean that the mechanical linkage from the front wheels to the steering wheel was so badly damaged that it was totally useless. Is that correct?
