So you think it's easy owning an RV Park ???
BTW Bill (NWIP) the Sheppard's are here. They seem like very nice people!
Thank you.
I've been thinking of starting a thread where I (and others) can post some of the craziness that takes at the RV Park. So let me start this thread off with today crappy happening.
Preface: At our park, we have 2 sewer connections at each site. This helps accommodate the newer rigs that have two sewer outlets as well as longer/shorter rigs that may need to access the sewer from different locations.
Today a departing guest was dumping his tanks. Instead of using either of the sewer outlets, he dumped into the 4" pvc pipe (with the green cover that says WATER) and goes down into the ground where the water on/off valve is. So now we have 2.5' of human waste filling up the PCC pipe that protects the water valve from freezing.
When the waste started coming over the top, the neighbor yelled at him and told him what he was doing wrong.
And no, the guy didn't even bother to tell us what he did. He just high tailed it out the park.
Thank you.
Stayed at a park in Liberty Lake, Idaho. Newer park. They had the water valve within 2 feet of the sewer. They told me the same thing had happened on numerous occasions. Even their check in instructions warn not to confuse the two. Colored tops too. They blamed it on the new, inexperienced rv’ers. But to drive off… send them a major bill
Dirty Hands Water GIF by CBS
Small shop vac. You can choose to save for next time or throw away after use 😳. Much cheaper than sewer pump truck
I agree with Bill. This is what your least favorite repair shop used when they screwed up the installation of my Sanicon. And, about a gallon of concentrated Lysol to finish the job. The tech who did the bad install had to clean the shop vac.
I think you should tell the the guest to get his A*# back to your place and help you clean it up. If not send a big bill to him and say persona non grata forever.
X 4 or 5 for a cheap, one time use, wet/dry shop vac. Or if you get it at home depot, you could return it - tell them is a….well you know.
The shop vac idea does sound a bit less messy than my poo volcano suggestion. If you do get one, make sure you get the 2 1/4" hose instead of the smaller one to avoid plugging it with camper mud!
It sounds like vacuum rinse repeat. Sanitizing when finished. I guess a name will be added to the no return list.
And it's probably the site I have reserved in a few weeks.
I personally know two owners of parks and the horror stories are endless. It's amazing the "stuff" they find in sewer lines that not only stops them up but plays havoc with the lift pumps and also how the washing machines are abused. I tell both of them they are crazy for owning the parks and I'll probably tell you that when we meet.
I agree, dress yourself in a hazmat suit and vacuum away.
We've discussed it and he apologized. Said that he has never been to a park with two sewer receptacles, and he got confused. It's OK. If this is the worst thing that happens to me I'll consider this venture to be a cakewalk. lol
Maybe add a couple gallons of bleach and black tank treatment to the mess first and let it sit a bit. Its unpleasant but in the grand order of things, human waste is a mangable bio hazard with minimal risk when handled properly. Its just extreemly unpleasant (for most people). Tyvek suit (avail from paint stores), gloves, booties, duct tape all seems, splash protection over your face (!), equip yourself with anything you need properly ahead of time, have a containment strategy in place, and dig in. Or you could just call someone who does this and watch them deal with it. $500 is sounding cheap about now. After the smells dissipate and the nightmares subside, it will just be one of those campfire stories about experiences you’d prefer not to repeat.
After the joy and lessons learned, how can you prevent this from happening again? White PVC I think we're trained to see as sewer, green as water. Maybe paint the respective non sewer pipes green, maybe put a cap on them with a label "water" or something to prevent anyone from connecting to it in any fashion to protect your water supply?
I’ve never stayed in a place with sewer hookups, so I’m certainly paying attention.
Maybe “water” is not the best word as many consider effluent as “water” ie Black water, Gray water, etc.
How about "explosives" or
Thank you.
Cool glad they visited, tell them we said hello.
All that is already in place. Since I seldom have to access this area, I'm going to find some way to put a strap over it and secure with screws or a bolt. Hate using screws in that close of proximity to the RV's though, as there is always a chance for a screw to get loose and find its way to a tire.
