Texas Clodhopper
- Nov 16, 2019
- Garden Ridge, TX
- Ventana 4369
- Longer daily
- Freightliner
- Cummins
- 2022 GMC Canyon AT4
Aug 22 07:04:33 | WAN: Cellular (Priority 2) disconnected (WAN failed SmartCheck) in SIM slot A |
Aug 22 07:03:58 | WAN: Cellular (Priority 2) standby (33.80.101.178) in SIM slot A |
Hi mag- I have a 2nd generation Starlink and I just put it on the ground and it runs great. I have the router in the bay where your girard awning plugs are located and run the cord through the middle of the rubber seal as there is a slit there and then close bay door.Hi - just looking into getting starlink for my 2022 newmar london aire - for those that use the standard mobile (not the mounted flat high performance) - what have you found to be the best way to mount once you get to your destination? Does it take awhile to lock onto a signal? I optioned for a flagpole mount when I ordered my London Aire - can I use that somehow, or do some of you just put the unit on the ground? And, then, what's the best/cleanest way to run the wiring to the inside modem? Also, I assume if I have the standard mobile - I can move to a nearby cabin to use as well, when I am not in my RV? And, is it easy to pause service when you know you will not need it, or do you have to plan relatively well to utilize that option? Any other info/advice you think would be helpful would be greatly appreciated - sorry for all the questions...I am definitely a newbie with these techy things!
