mag rv lady
- Aug 21, 2024
Hi - just looking into getting starlink for my 2022 newmar london aire - for those that use the standard mobile (not the mounted flat high performance) - what have you found to be the best way to mount once you get to your destination? Does it take awhile to lock onto a signal? I optioned for a flagpole mount when I ordered my London Aire - can I use that somehow, or do some of you just put the unit on the ground? And, then, what's the best/cleanest way to run the wiring to the inside modem? Also, I assume if I have the standard mobile - I can move to a nearby cabin to use as well, when I am not in my RV? And, is it easy to pause service when you know you will not need it, or do you have to plan relatively well to utilize that option? Any other info/advice you think would be helpful would be greatly appreciated - sorry for all the questions...I am definitely a newbie with these techy things!
