Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
So as the article states the atmosphere has roughly 80% nitrogen. Those places like Costco that fill with nitrogen, have nitrogen generators.Nitrogen vs Air in RV Tires - Good Sam Camping Blog
When it comes to getting the most life and performance out of your tires, consider the benefits of nitrogen vs air.blog.goodsam.com
The advantage that comes to mind according to my research on the subject was only touched in the article.
The static created within the tires while you go down the road creates Ozone. Ozone is destructive to rubber. (Filling with nitrogen eliminates checking from the inside of the Tire). .
As the oxygen seeps through the Tire because of the pressure, the tire actually works as a nitrogen concentrator(generator), over time all the oxygen will seep out of the Tire leaving nitrogen and moisture. That is the reason for topping off tire pressure, by the way! It is also why you should be separating the moisture/oil from your compressor.
Using the tire for this purpose however oxidizes the carcass of the tire, so is detrimental to the tire life.
3/8 in. NPT(F) Desiccant Dryer and Filter
Amazing deals on this 3/8In Desiccant Dryer With Filter at Harbor Freight. Quality tools & low prices.
www.harborfreight.com
