We know nothing about motorhomes. We are looking toward retirement and would like to buy a motorhome and tow our Ford Ranger. Will a class c do that or do we need to go to class a? Should we look for a diesel? We are looking at spending around $100000. Any advice you can give us would be greatly appreciated on what would be good to buy and what to look for.
I may be the outlier here but this is what I have found in 20 years of RVing
Gas or Diesel?
Really with any newer Class A or Class C (less than 10 - 15 years old) you can tow the Ranger easily. Many, maybe most people will tell you to get a Diesel. I say no, they cost way more to purchase
They cost way more to maintain (a oil change could cost as much as $500 or more for example) .
They don't get any ( or only marginally better gas mileage).
Diesel fuel generally costs more.
Diesel cost way more to repair if you need repairs, WAY MORE!!!!
Diesel can be hard to find in some areas (especially in Canada *
if they ever let tourists back in)
Flat tow, or Trailer tow?
Again, A lot of people will say "what are you crazy"? Having done both, and also having pulled double trailers up to 85 feet in length I say
NO, DO NOT FLAT TOW!!!
WHY???
1. You can not back up Flat towing.
This is always a problem due to
A wrong turn
Setting up at the campsite
Maneuvering at the gas station
Didn't quite make a tight corner
Accidently on a dead end road and unable to make a sweeping U turn
And the list goes on
2. Fuel
mileage is better towing a good trailer ( like maybe over 1 MPG better, and at 5 to 10 MPG * 1 MPG equals 10 % to 20% lower fuel cost)
3. You can carry extra stuff on the trailer
Bikes
Kayak
Other toys
Your mother in law
4. To those who say "well yah, but what do you do with the trailer when you get to your destination?"
1 This is rarely an issue, just park it (hooked up or unhooked beside the motorhome) on your camping site
2 Have to park it somewhere else, Park it there using the motorhome or, that Ranger, you have a hitch on it? use the Ranger to park it away from your campsite. (I have found that during the course of my average 7 month summer trip I might need to do this once or twice)
Class A or Class C?
I would say this about that
1. Are you going to go on trips for a weekend or a week or two? Class A or Class C is fine
2. Are you going to go on trips for Months at a time? Get yourself more room with a Class A (more storage room too)
3. Are you going to live in it for a year or two? get the biggest one that you can afford. Do not worry about the size in regards to driving it. Get the biggest on you can afford * note exceptions below.
4. Exception to rule "Get the biggest one you can afford"
1. If you plan of doing a lot of camping in state parks, national parks, or national forest campgrounds some do have max size restrictions.
2. Generally the max size restriction is 35 feet (but I have never seen anyone out measuring a motorhome to see if it violates this rule) and I have seen plenty of motorhomes that exceed the size restriction in places where technically they are not allowed. So are you willing to push those rules?
3. And you may ask, if the site says 70 foot long site, why is there a 35 foot restriction rule? GREAT QUESTION, my guess is politics
4. For years I traveled in a 35 footer and now I have a 45 footer and I can honestly tell you I have not changed where I am going to camp based on the size restrictions more that a few times.
Finally Warnings about buying a unit
1. Best time to buy was last year
, truthfully, Prices are sky high right now do to a lot of reasons
2. Best time of year to buy? Between November 1 and February 1 in any year is when you are going to get the best deal $$$$, most likely best in November and December
3. Buying a gas unit? If you have any mechanical experience (you do your own auto work) then you can probably check the engine, drivetrain, suspension, and brakes yourself.
4. Buying a diesel, If it is more than 5 -7 years old, Have a great diesel shop look it over for you! Why?
1. Air brake systems are completely different from hydraulic brake systems, you need someone who knows what they are looking at
2. Air suspension systems are also completely different and require maintenance! Also air bag suspension systems are more susceptible to damage and the bags do go bad over time.
3. diesels need to run, Well gas engines too but diesels are made to run 750,000 to 1,000,000 plus miles, so if you are buying a 5 year old unit with 20,000 miles on it ( it was not run and may have issues due to the lack of use) "MAY"
5 Any used motorhome,
Check the roof carefully!
Check all vents, wiring, TV antenna's, etc. for broken or cracked plastic, and bad caulking, sealing around any roof penetration's
If a rubber roof, make sure it has not become loose in any area, or has a bubble (those are expensive issues to repair)
Heating, Air-conditioning, Refrigerators are all expensive to repair or replace, turn them on and make sure they work.
Fill all tanks (water) to full, including Black and Grey water tanks and look for leaks in tank and plumbing
Hook up to water source and see if there are any plumbing leaks
If it has a generator , run it for at least an hour with A/C , or other high consumption electrical items turned on
Of course ask for and review maintenance records
NOTE: All motorhome dealers have negotiating room on their prices (and they are insanely high right now as previously noted), and also most will fix problems you identify before the purchase as part of the deal, but will charge you up the @@@ to fix it if an issue if found after the purchase.
AS you can see, I could go on for a long time, but with the info above you have the basics.
BTW, join FMCA and attend rallys, seminars to gain more knowledge.
Johnnie
