MOD Upgrading my Pepwave RV Internet setup
oh boy. I like that. My hand is poised over my wallet. I'm a little conflicted..maybe.
Couple questions.. what are you thinking for the antenna? I ran across this while considering using my current 7-1, Sharing one MIMO LTE antenna between two modems - LTE HACKS
Also, does your unit run hot? Mine does and others have mentioned this as well. I'm also thinking where I'd mount the second unit. I might stack it if I could get airflow between them. Time for a swanky 3-D printed solution @Neal!
5GStore.com is giving me good quotes based on my prior order history I presume. Can't pass up the pricing for what I'm getting, i.e. CAT 18. I really wanted to go SIMPLE and just use one and probably should BUT there are advantages of the active/active setup I've been taking advantage of for two years.
  1. Fast network switching
  2. Put both in Priority 1 and let Pepwave decide who to use
  3. My coach connects to primary on WiFi for all of its needs. My computer for example can WiFi connect to Pepwave 1 for my Internet needs. I can connect my iPad to Pepwave 2 and watch TV, videos, streams, etc. without affecting my work on the computer as it's a separate WiFi and cellular network. Typically I work primarily on AT&T and the iPad can use Verizon for the media.
I have Pepwave PUMA antennas for the new Pepwave CAT 18 going on the roof tomorrow. One is a 5 in 1 (4 x 4 MIMO + GPS). The other is their WiFi version (2 leads). I'm undecided if I'm going roof antennas on the 2nd unit. Most likely I will and have already requested a quote for the same antennas. Are they the best? I have no idea. I like the numbers, we'll see what the results show but again, so hard to compare as even a reboot shows different results on cellular. My problem is that inside the RV much less the A/V compartment seems to be so much electrical noise. It may not be a conflict on the cellular frequencies but I have a terrible time getting FM reception on my home theater receiver. Dash radio does fine but not the AV receiver.
I have 2 x USB Fans in my AV box to help remove heat. Electronics get hot and are designed for the heat, doesn't concern me. But I do try to help matters with USB fans.
My plan now is Pep1 roof antennas, Pep2 paddle antennas. I will probably but both Pepwaves in the over driver's seat AV box but I am thinking hard on putting one in the half bath electrical cabinet sidewall mounted. I just wish I had ethernet to connect the two but realize I can use WiFi as well but I don't want one stepping in the other WiFi comm jamming so this is driving me to put the two peps in the same cabinet as I did before. I really need to figure out the path to get Ethernet down from half bath electrical to basement, then I can easily get it to the over driver cabinet.
3D printing an extra set of antenna mounts now. I designed two already, one for cellular and a shorter one for wifi so it's not on the same plane as the other antenna and causing any blockage. I leave for my big trip next week so I better get two more mounts printed in case I go with roof antennas for the 2nd unit.
@Neal We have the central vacuum on our 2015 4369 Ventana which provides a easy path to the basement from the narrow cabinet to the right of the electrical cabinet. Not sure of the layout on your 4037 but thought I'd share how I got there on our coach.
Very interesting. Thanks. I’ll look at that.
I ended up putting both Pepwave MAX Transit CAT 18 routers in the A/V cabinet over the driver's seat. Just made more sense and I 3M hook taped them to the walls so it's a very clean install vs. my last setup which was a bit messy. I have two sets of antennas on the roof using the Pepwave PUMA antennas. 4x4 MIMO + GPS 1 for each unit and the WiFi puma, 1 for each unit. Installed using my 3D printed mounts/towers which are perfect, they line up with the top of the air conditioner.
Speeds have been interesting. This morning I tested my iPhone 12 Pro MAX on AT&T and I hit 100 down. Pepwave was struggling around 30 with TTL of 65. I cleared the TTL values on both of my pepwaves and they both went to the moon at over 100 down so I'm leaving TTL to auto. Maybe it's different with CAT 18, I don't know. I don't really know the tech details with cellular, it's so random and hit and miss. What I do know is the Pepwave CAT 18 are absolutely killing it. Speeds tests along highways at random areas are all super high speed.
Absolutely thrilled with the Pepwave CAT 18 setup. I have no intention of swapping between paddle antennas to compare but I believe the paddles are just as good, who knows. As it's now 6 antennas to change out (4 cellular, 2 wifi) I'm not doing it. I'm sticking with the new Pepwave PUMA antennas and so far they are exceeding my expectations.
Great to hear Neal. Interesting point on the TTL.. I've tried 65 and 64 and not found a difference. I might try the Auto setting again and see what happens, thanks for mentioning. I bet that guy who convinced them they needed to add this feature is feeling kinda sheepish now huh? ;-).
You have a great setup with two active Peplinks-pretty envious! You have SO much flexibility. I thought about doing the same but am working some other angles before I get there.
As to TTL, I just don't know. Prior to the CAT 18's it really seemed to help. I don't know the right number to enter but 65 seemed to work well. I wish I had real knowledge of the cellular engineering to be able to better advise but I'm like many just experimenting and seeing what works. Maybe Peplink has made some changes in more recent firmware that handles this differently, I don't know (get the theme??).
Neal,
As I understand the Cat-18, as a general rule, it's best to let it manage most of the cellular & WiFi 'settings'. That's supposedly what it does best & your experience seems to support that. I've yet to install my roof top antenna, but, the cellular & park WiFi (good WiFi at the park I'm in) signals I obtain with the paddle antennas provide all I need.
Only thing I've had any real issue with is connecting to the NAS on the RV remotely (wanted to backup NAS in home office to NAS on RV & vice versa).
@Neal I've seen a thread somewhere that you guide through setting outbound policies for your Pepwave setup. I've searched high and low. Can you direct me?
Just got my new Max Transit Duo and am excited to get it fully setup and load balancing. Thanks
I have a synology NAS in my coach and I have it set to a fixed IP address, not using DHCP. I then setup port forwarding for ports 5000 and 5001 and it points to the fixed IP address. See attached. I created a new "service" named it NAS and configured as shown.
Really shouldn't need any outbound policies, the one that's setup by default should suffice. I do have "persistence" policies setup for RDP and other services I use because of my active/active setup I can't have the IP address changing during a connection. You'll see the default for HTTPS persistence is created by Peplink for this very reason, you can't have a secure connection and then change providers during the session.
When setting up my new Pepwave MAX Transit CAT 18 my iPhone 12 complained about the WiFi security. The default Peplink uses for WiFi security is "WPA/WPA2 - Personal". The problem is the "WPA" (first part). That uses TKIP encryption and the better security is AES. To fix this you'll need to change this to "WPA2 - Personal".
On another note, I am amazed at the power of the Pepwave and PUMA WiFi antenna on the roof. I was at the dog park at my current location (KOA) which was over 100 yards from my coach. It was distant and behind the coach (antenna is at the front on the roof). I was getting 2 out of 3 arcs in WiFi antenna strength and the connection was solid and fast. Very pleased with the Pepwave PUMA antennas I got with my units. The 2nd pepwave has WiFi OFF, I only use it on one typically. There are scenarios where I'll connect devices to the 2nd unit so as not to interfere with my speeds on the primary unit.
With regards to the NAS issue I encountered. My problem was NAS to NAS communications for backup of the devices from home/office to RV & vice versa. The home/office NAS could not get to the network on the RV due to carrier grade NAT. Problem was resolved with PepVPN SpeedFusion. CAT-18 on RV, Peplink Balnce One in home office.
Not sure if the question was directed at me. If not, my apologies.
Correction/Improvement to the WiFi security protocol mentioned two up. I was browsing network preferences on my mac and noticed most of my WiFi passwords were saved using WPA2/WPA3 - Personal. Pepwave came defaulted to WPA (bad) and I changed to WPA2 - Personal. I have since changed again to the more secure WPA2/WPA3 - Personal setting as that seems to be the current standard.
Back to TTL of 65 showing good results in this weird area. I'll leave it as I have been for the past year with TTL 65 set.
Funny, I JUST set my ATT to 64 yesterday and ran a quick speed test and then set it back to Auto...no difference. I’ll try 65 again.
I wonder if regions and bands make a difference?
Yeah, I tried 64 yesterday as well. I tried googling what people are using and it seems 65 is the number mentioned most. Wish Peplink could offer guidance but haven't found anything from them.
I also read AT&T doesn't seem to care about TTL, not sure I agree. I'm sticking with 65 for now. During travels nothing set worked well but here where I seem to be competing with others something is different. TTL 65 is giving me 100 down now where I was struggling to break 5-10 yesterday.
Here's a helpful guide from 5G store for Outbound policies and Speedfusion testing. When I saw this a week or two back I made a note to go back and check my setup. Finally had a chance today. I use the persistance setting as Neal mentions, but also use Outbound policies to setup Load Balancing, which is a primary value of Peplink with multiple connections in my opinion. I also have prioritization setup for VOIP, and am working to setup the best policy to keep my Apple TV Traffic off the Speedfusion VPN, as I don't want to use that bandwidth too quickly right now.
TTL made no difference, it was just morning is faster, now it's slow. Hate cellular, it's not like an ethernet cable with fiber connection. And providers are having to play games with their demands it seems so nothing is constant.
