Question When was the last time you exercised your GEN?
Administrator
Cummins 400 HP
Okay, no cheating. How long ago did you last run your GEN or exercise your GEN?
Mine is running now as the pedestal breaker tripped. I reset the breaker but I want to make sure I get through this laundry and I need to exercise the gen. It's been 1-2 months since I last exercised it, I haven't been doing it every 30 days but it is in my crosscheck so I'm exercising it now.
Truth up....when is the last time you exercised your GEN???
I did mine about three weeks ago and it will be due again next week. My schedule is monthly, but occasionally I do slip a bit.
Interestingly, the new 22K whole-house generator we just had install at the sticks-and-bricks is programmed to exercise every two weeks (alternate Tuesdays at 10 am). It is due again tomorrow morning. Nice to have it programmable.
I think you can program it in the Magnum control panels but I don't.
I ran mine around the first of March, when we were boondocking in a Walmart parking lot...time to run it again. I shoot for monthly.
Typically at least once a month. Having an AGS is of no value if the GEN won't start:) AGS tries three times then stops after third attempt.
I was just saying this morning I should exercise mine, last was beginning of March. I shoot for once a month but sometimes it ends up being 6 weeks
Usually once a month except when the temps get down in the teens and single digits. So sometimes I may skip a month in the dead of winter. I do have the generator serviced yearly, rather than the suggested schedule by hours.
A little over a week ago when we were at North Trail to have the drivers seat footrest replaced. Before that, when my 300amp fuse blew.
Ooops! Okay, so it's been since mid January. Guess, I'll get on it tomorrow.
Try to run mine monthly. Last time was March 21st. I run it a minimum of 30-45 minutes. I start it, no load on it. Give it about 5-6 minutes to warm up, then gradually put it under load, until I have both heat pumps running, & if not winterized, turn on the water heater. Let it run under load for about 15-20 minutes, (if it's cold outside, let it run til the coach heats up); then will shut down heat pump, one at a time, and after that I let it run with no load for 3-5 minutes, then shut it down. When running it, there should be a load on it for a short period of time, to properly "exercise" it.
That's my generator exercise program!:)
So, apparently, I exercised my generator this afternoon. :oops: Just went out to check something on the coach and the generator was running. The auto exercise function was disabled (though I now know where it is and how to set it) and the shore power had not been interrupted. The batteries were both at 13.6V With float charge on. I have no idea how long it had been running, the the max run-time was set to 240 minutes.
Anybody ever have this happen? Any thoughts on what's going on? My whole-house generator exercised at 10 am today; was the coach generator feeling left out?
I'm puzzled. Comments appreciated.
Had it happen once in my Alpine. We were cruising down the highway and the genset fired up all by itself. AGS was off, coach alternator was fine, batteries full, no a/c running. Only did it once and never again. Gremlins I guess. Weird stuff??.
I get lazy while stationary in the winter. I try to run it about the middle of my stay. During the rest of the year I pretty much run it whenever we are on the road. If there is no real need for it on a travel day (no air needed or no heat needed) I'll at least crank it up on a lunch break for 30 minutes or so. I guess you could say it gets ran every week or two.
