turbopilot
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV
If you are headed to a replacement of the flooded/AGM lead acid batteries I would jump to a 48 volt system. I think the days of 12 volt battery systems are limited for Class A coaches. I would do 48 volt right now for the 2024 NA but it would mean getting rid of the new equipment and a bunch of rewiring.
Yes, those are the folks with the Rettroband right front tire failure. Sure would like to see the 4 corner weights on that NA3343. With full fuel and water but no cargo or anyone on board I only had 1,800 lbs left on my NA3343 to load the front axle with payload. They did have 500 lbs to work with by pulling the AGM batteries for the lithium but that solar array rack system looks heavy and that 48 volt system added additional weight over the 12 volt system.Not on board with this personally, I have solar and hardly use it. In a New Aire I'm sure storage is a premium and for me I'd want all space I could get for my junk.
This is the initial reason for my solar install. I was in a storage facility (outdoor) with no power, etc. Solar worked well. Then as you mentioned when in service facilities, batteries were not at risk of going dead. So for that reason, yes. For boondocking I may have had 3-4 real opportunities but due to fall or winter timing with low solar declination it was tough to get good PV.The time when solar really pays off is when you have to leave the coach for service (or other unplanned events) and it is not plugged in.
I watched about half the video and that system is pretty much what I suspected. Its more about everything you can do with an unlimited budget and no consideration of actual need, use of space, and cost/benefit. They created a system on a 35’ coach that can run four air conditioners and charge in 90 minutes. Great, but why?I have solar, I installed it as I had a need for it (and could again someday) - storage without power, and there is also the times when in service and parked in a lot it can help prevent house batteries from going dead. Beyond that, anyone looking at solar needs to think hard about the need. A modern class A with ultra-quiet gens I question that need. Even if parked in storage or service per above, if AGS is set (and not disabled by the service) the gen can automatically come on and maintain the batteries (notify them to be safe). Then of course for those that want to boondock, again, think hard about your needs as I bet in 75% of the solar installs out there, there is no need.
Take for example simply replacing FLA/AGM batteries with LifePO4 giving you a larger spectrum of usable battery and also faster recharge times such as from a GEN. This further negates the need for solar IMHO. Put the money towards a sufficient and correct LifePO4 install FIRST and go from there. Solar panels and solar controller are the cheap part of the setup. LifePO4 batteries first, other components secondary IMHO if I did it over again. I believe good batteries is all "most" here really need.
Edit: I'm curious of how fast a GEN can recharge a LifePO4 bank. Need to know the charge rate for LifePO4's and how long a GEN run would be required for recharge.
Edit2: Just my $.02
.......... Net system weight for this conversion (48 volt lithium batteries, 48 volt alternator, two Victron inverters and a lot of solar on the roof is around 1,500 lbs. ......
What about the fire supression system?
I hav'nt watched the video yet, but.. I have been to their shop and seen the installation first hand. Likewize, it seemed geared more to the 'unlimited budget', just to have it. Though, they seem to do a nice job. All wires color coded (for the 48V), the installation we looked at, had a fire suppression due to the extend of hi-voltage.
Now, if the factory designed this from production and within reason may be worth considering, given, their cost should be lower and given as much padding in the cost of a new coach, they can easily absorb this expense, if not most of it.
I would approach the project differently. I would remove the 500 lb, 8.2 kw generator and replace it with a climate controlled lithium battery/inverter enclosure in the previous generator location. This would dramatically reduce the weight penalty. It would also free up additional belly storage.
one of the big companies had a demo model like that last year. Might have been Thor…..? Although I don’t know if it was 48v. When I was toying with this idea, I was going to use a Victron 48v 8kw inverter.this has relevance, be nice for the factory to offer the option, a genst with the original 12v system or have the LI Batt/Solar 48v system with no gen.
Post some images when you can of the 3rd battery install.I caved and had the dealer's service department do the 3rd Lithionics battery "plug-in-play" upgrade as the coach is still under warranty and I wanted Newmar and their fingerprints on this.
Not really a shot at Victron! Just a few short years ago the DIY battery builder had hoops to jump Just to get supplies to build their own batteries. Regulation due to it being a safety hazard, was in fact the legitimate reason it was so.There is a video on YouTube interviewing a Lithionics spokesman who have said they do not want to play to the DIY sector for "safety" reasons (obviously taking a shot at Victron). So I think we are stuck.
And, at the same time those same insurance companies were paying big dollars for all the RV fires cause by propane absorption refrigerators. Nothing rivals the risk associated with using propane in an RV.Not really a shot at Victron! Just a few short years ago the DIY battery builder had hoops to jump Just to get supplies to build their own batteries. Regulation due to it being a safety hazard, was in fact the legitimate reason it was so.
In that day 4ahrs was a typical cell size. Imagine 320 ahrs in Roman candle fashion show.
Same time period insurance would not cover a fire on a system, not installed by a licensed lithium installer.
Other "Banned for Life" iRV2 refugees may remember Mike Mas on that forum. He was one of the very early buyers of a New Aire in 2017 who brought lots of new technology ideas to the NA and posted regularly on iRV2 for a while. As I recall he got crosswise with the moderators on iRV2 and simply left the forum. Here is his web site.
A year ago Lithionics posted a video by Mike that is detailed and wide ranging. He is pushing for high voltages in RV's using these lithium based systems. I think he is on the right tract. I have Ford F-150 hybrid. It is running with two DC electrical systems: 12 volt and 280 volt. The 280 volt system runs the air conditioning and traction motor. Mike is arguing we need to step up to a 51 volt system for RV's. He makes some good points..
Here is the Lithionics YouTube Video.
I get it!!! You will get your wake up call, as more RVs have lithium installed!!!And, at the same time those same insurance companies were paying big dollars for all the RV fires cause by propane absorption refrigerators. Nothing rivals the risk associated with using propane in an RV.
Does that make us neighbors?Success! I talked to T. J. at OffTheGridRV in Quartzite, AZ. They are an authorized Lithionics dealer. TJ has added the 3rd Lithionics battery to 3 "Luxury" Newmar coaches. Last one being a new Mountain Aire. T.J.'s current price is around $6,900 for the full install versus $10,000 as a factory option. The 3 port parallel combiner box is more expensive than I thought at $1,300 and is included in that price. Battery alone is $4,600. Apparently there are no SilverLeaf changes needed to support a 3rd battery. All configuration of the Lithionics BMS is done through the Bluetooth Lithionics app. The Lithionics BMS then echos information to SilverLeaf via the RV-Can network. With the parts, installation is fast and easy according to TJ. TJ needs about a month lead time for the some parts.
Everything here applies to any new "Luxury" Newmar model with Lithionics batteries. Here is the complete installation in the Mountain Aire.
LFP batteries don’t have the same thermal run away characteristics of Lithium Ion, tons safer.So all y'alls know Lithium Iron Phosphate batteries are not the same as Lithium Ion batteries, right?
Best,
-Mark
